any suggestions on which program captures the best (using canopus advc-100)?? Any significant advantages to using one over the other?
I use avi_io on my AMD 1.33ghz and caoture at 480 *576 with huffy and never drop frames dam good program worth every penny
CHEERS GARRY -
AV-IO has built in VCR like functions with seamless multisegment captures.
I find it is a lot easier to get the correct settings for capture with AV-IO.
I use AV-IO for captutre then edit the capture with Virtual Dubb.
AVI-IO is wotht its price US$25
Sherman -
These programs use VFW right? I can't use VFW and the wrapper causes VDub to go into panic mode saying it can't find it. Meanwhile, a program like Video Capturix finds it no problem. Moot in any case as WDM is now controlling the marketplace especially for new capture hardware. Looks like major rewrite time ahead for these VFW only capture solutions...
VirtualDub, even if enabled with the vfwwdm wrapper is heavy on your
system (easily drops frames and leads to a/v sinc problems) and will
not allow you to use divx 3.11a f.m. (div4), if you happen to choose it
-- only the low motion version (4.v3 = div3).
AVI_IO will keep your selected framerate but will limit input bitrate to
its deafault, no matter what you've priorly selected.
But FlyCap (w3.asvzzz.narod.ru) offers you superior options within multi
specifications and perfect stability, being very light on demands to yr. rig.
And it's Freeware.
If you work with wdm & a capture card you'll have to buy FlyDS, though.
Regards,
HN
VirtualDub video skipping while capturing
By kurtdani in forum Capturing and VCRReplies: 21Last Post: 4th Dec 2011, 14:48 -
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59
