Hi
I am having a problem with an application called "Link2". It occasionally pops up with an alert saying it is unregistered, and there's only one button to close it..... which brings Internet Explorer up and takes me to its homepage.
Apparently, I have to either register it or remove it. However, I can't find any way to remove the damn thing!!
What is "Link2", and how can I get it off my system?
CobraDMX
I've never used it but a search of Google yielded a site with this information:
This program is designed to add additional input formats to programs who can read AVI files. This program adds a new input engine to the existing programs and feeds the video/audio through the already implemented AVI interface. Currently my program is designed in such a way that it adds support for Avisynth, Virtualdub frame
server files and AVI files with and without compressed audio. So this tools enables you to e.g. read Avisynth files in any program that reads AVI files (Like Premiere, CCE SP, Ulead Media Studio Pro )
and the install information...
Unzip the files for Link2, aviwrap.dll and aviwrap.inf into the directory c:\link2. (do NOT use long directory names with running W9x). Launch the Windows Explorer and select the aviwrap.inf script. Press the most left mouse button and select install. This installs the AVIwrapper code. Now you can run the Link2.exe program from any location you want.
Hope this helps.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
