I have backep up a dvd using osex and studio pro. when i play the dvd on my player it does not work. I asked a friend to try his player and the disk worked fine. Do i need to alter my settings when i rip the file. Burning in toast titanium 5.2 on an imac superdrive with mac os x 10.1.5.
Look up your player's info from the section on DVD players to the left. You could have:
a player that doesn't like DVD-R
a player that doesn't like DVD-RW
a player that doesn't like that high of a bitrate
a problem with the authoring of the DVD (make sure a startup action is set)
Unfortunately, all you can do is test. Good luck.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35 -
problem playing burned .iso dvd in my dvd player
By method in forum DVD RippingReplies: 6Last Post: 5th Dec 2007, 07:12 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
WinAVI Video Converter 8.1 (DVD gets stuck while playing on home DVD)
By Zuzuu in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2007, 13:37
