Hello. I´ve downloaded EasyVCD 1.12 and the ASPI recommended for XP (I´m using XP Pro) but I always get Error type 62. I´ve tried everythig. Reboot computer after installing ASPI, Play a few seconds PowerDVD, etc.
I´m trying to rip a new original DVD purchased by me (region 2) in spanish (Los Otros).
Could anyone help me?
Thank you.
Hmmmmm i use to get that error, but all i did was reinstall the program and it worked, dont know if that will work for you. There is suppose to be a new version sometime this week, hopefully it will fix that bug.
I've just uploaded a new version of Eazy VCD to my website, this should fix your problem.
DVD to VCD made eazy
http://www.eazyvcd.tk -
Possibly related, I've always had to install the Compel Win ASPI to get VCDeasy to function under '98. Solves a host of other problems.
See
http://www.vcdhelp.com/forum/viewtopic.php?t=91356&highlight=
and
http://www.softdeko.8m.com/dvd_ripper_software.htm
PN -
I just used the 1.14 version of EazyVCD, KICK ASS! this is really neat! I just have one quetion. I noticed that there is no differnence from SVCD and XSVCD because the resolution and bitrate are exactly the same....
the XSVCD feature won't go any higher than 2520 and 224, as most DVD players don't support it, in the next release, i am planing on putting in an advanced features button where you will be able to set the max bitrates and the like.
