Hi all
So, I'm converting avi to svcd. I usually add subs ( permanent ) with vdub textsub.
problems: If the sub consist of three lines, then when applying it to a letterboxed 16:9 ratio movie on a 4:3 TV, then the rhird line doesn't fit on a screen ( char 16 is the smallest one can read, I think)). I'd rather keep the 16:9 ratio cause I'm planning on a SONY wega 8)
So if I could somehow force the textsub filter, or the .sub to break itself into two lines ( no more ) than that could solve my problem
Or if I could specially letterbox the movie, by only adding the lower black border ( of course double size ).
Anyone who knows the anwer pls help
( anyway what do you think, how would a movie with that special letterboxing look like? I mean, wouldn't it be unusual => crap? )
you could try conversor
http://www.divx-digest.tv/software/subtitle/SRTtoSSA.zip
in this program before the conversion there is a setting called :
"Dist to the borders"
The ssa output file can be used in virtualdub with the subtitle plugin form avery lee
http://www.peque.org/divx/subtitler.zip
Peter
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
