When using bbMPEG (multiplex) I get some remark that the MUX rate might be to low.
And yes, the endproduct is bad on sone spots.
What does it mean? What does MUX do anyway?
What are the normal values for SVCD mpg2 stream?
I know this isn't about tits, but sure worth to give a reaction too... no?
Mux is short for Multiplex. It's the process of mixing two or more things together into one thing. For mpeg it means mixing video and audio. The rate controls how much video and audio is stuffed into each data packet of the stream.
I don't have access to bbMpeg at the moment, but, I believe the default for a mpeg2 program stream is a mux rate of 0. Which means bbMpeg calculates the mux rate according the the files you give it. -
Hi Darkbird,
When I choose SVCD in bbMPEG to multiplex, it gives me 6972 as mux-rate. (bbmpeg 1.24 beta 1
Don't know what happends if I make 0 of, but will give it a try.
Thanx for your answer.
Rgrds, Co.
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 12:07 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 08:52 -
Mux audio
By jgv115 in forum EditingReplies: 2Last Post: 18th May 2008, 01:56 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
