(continued on from a post i made a long time ago)
Ok, now ive bought my little minature TV:and on the side it has an AV in jack. The AV in jack just looks like a tiny hole that you could fit some normal headphones into. But it is for Audio and Video input. Now last time i posted, somebody said the Auidio and Video are converted into one for the TV to play, so if i want to connect the RCA cables from my vcd player to it, i will need an adapter right??
I was thinking that this is what i need:
is that what i need? Or is this what i need:
If anyone has the TV i got connected to a vcd player, could you please help?
I think it would probably be closer to the photo in the middle which is a 3.5mm stereo to 2 - RCA "Y" adapter.
That might work but I think the 3.5mm male plug might only need to be mono.
Do you have a Radio Shack or Tandy type store near you?
If so,I would take in the TV and try the avaulable choices (they may even let you hook it up to a video output to test it.
Just remember that the input will be mono sound and it would have to be 75 ohm output (at least here in Canada it is)......although the Line outs might also work..mmm!?.
Rather than guessing ,I would take it in to a Radio Shack type store."Today is only yesterdays tomorrow"
