TMPGEnc does NOT create Strict PAL VCD Compliant Mpeg System Streams.
(Xing Encoder and the Panasonic Encoder DO Create Fully Compliant
Mpeg Streams)
TMPGEnc is encoder with better Quality, but because it does not
create compliant PAL VCD streams my DVD Player causes intermittant
frame drops on Playback.
Anyone have any PAL VCDtemplates/settings for the correct IPB GOP Sequence, VBV Buffer, Max Number of frames in GOP, etc
P.S. VCDEASY always reports a compliancy warning when using Mpegs
created with TMPGEnc. Mpegs created with other encoders...No Problem.(Except quality isnt as good as Tmpeg)
VCDEasy fixes that problem, you just have to select that option
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
