so i just downloaded nero, cuz i heard its one of the better programs to burn vcd's with. but when i went to run it, i msg box came up that said i had "auto insert notification" on, and it is highly recommended that i should turn it off.
my question is WTF is auto insert notification, and how would i be able to turn on and off this feature?
thanks for any replies in advanced!
Auto Insert Notification is where you put a CD in your CD drive and Windows automatically knows that there is a CD there and tries to read it (it will lauch whatever is specified in the autorun.ini file if one exists).
This is potentially hazardous to CD burning. A blank CD isn't particularly interesting to Windows. However, once the TOC is written, it does become interesting. Windows can be persistent and stupid enough to interrupt the burning process (= coaster) if AIF is left on.
I'm under the impression that most burning proggies automatically turned AIF off -- and back on if they are clever afterwards. If you want to do it yourself (Win95/9:
Start --> Settings --> Control Panel --> System --> Device Manager --> (your burner) --> Settings --> Uncheck AIF
I believe you can do this through TweakUI if you have that applet installed as well.
Regards.
Michael Tam
w: Morsels of Evidence
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
