Chrismast is around the corner, and I'm looking either of a Panasonic DMR-HS2 (40gb HD + Firewire) or a Toshiba RD-X2 (80gb HD).
Please help me out for which one is the best pick on this race.
Thanks so much.
Panasonic DMR-HS2 info:
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=168884&perpage=20&highlight=...2&pagenumber=1
Toshiba RD-X2 info:
www.avsforum.com/avs-vb/showthread.php?s=&threadid=178417&highlight=RDX2
www.avsforum.com/avs-vb/showthread.php?s=&threadid=195732
There will be a quiz later so I expect you'll answer most of the questions correctly.
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 15:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 23:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 16:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 03:12
