HI,
I want to buy good video capture card for use in my home country which has PAL system. The cards that are available in US have the input TV/cable connector which is different from the ones used in my country, where typically a 75ohm balun is used. Are there any cards available which supports both the NTSC type RF connectors in US and the balun connectors? Is there a way to use the same card in both places?
Also, can the cards available in the market for video capture like Pinnacle, Radeon 7500 etc be used for both PAL and NTSC video captures?
Thank you
Ravi
Results 1 to 1 of 1
Finding a Good Capture Card For An Xbox 360 System?
By LoC Blood Red in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2010, 23:06 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34 -
new system capture card analog and dv
By rikit in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2007, 20:44 -
Which Capture card is best for my system?
By coolbyme in forum Capturing and VCRReplies: 12Last Post: 19th Sep 2007, 15:25 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
