  1. ok I have Nero 5.5.9.17 and i have the full copy and need to know how to turn the buffer underrun off. I also need to know how to burn a cd over the amount in either Nero or Easy Cd Creator 4.
    thanks
  2. I'm not sure why you would want to turn off buffer underrrun protection but, assuming your drive supports it (some drives don't allow it to be turned off), you would do it by selecting "Recorder->Choose Recorder" from the main window. Then select the recorder you are using and press the "Options" button. Advanced options for the selected recorder will show up, and if you can disable buffer underrun protection, you will see it listed. Just un-check the box.
    As for overburning, choose "File->Preferences..." from the main window, then select the "Advanced" tab and check the "Enable overbun 'disc-at-once' burning" box. You must burn in disc-at-once (DAO) mode to do overburning.
    Check these links:
    http://www.cdrlabs.com/phpBB/viewtopic.php?p=39520#39520
    http://www3.sympatico.ca/brad.ormsby/
    cfitz
