I am having a problem that I need to fix asap. I have burned one DVD no problem using MSP6.5 and DVD workshop to capture. Now I am trying to put two 1 hour clips together in MSP6.5. One loads normal, while the other takes close to 4 minutes after I insert it into the timeline. I added a new drive and moved the data over but that did not help.
My system is an Athlon 1500XP, 512MB RAM, 30GB drive and new 60GB drive just for data. I closed most everything in the systray and it had worked fine with an 80min Mpeg2 file.
Where can I turn besides upgrading my cpu? I have to edit and finish 2 more DVD's for tomorrow night.![]()
Maybe I am not explaining it correctly, but all the other Mpeg's of equal length will only take about 5 seconds to load in the timeline and I can see each frame in filmstrip mode. The one file only shows up black in the timeline and takes 4 minutes to load.
To me, this does not sound normal. I have not done much with video editing, but still...
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 00:50 -
Load time differences for MPG2 vs MPG4
By icfriend in forum Video Streaming DownloadingReplies: 1Last Post: 7th Mar 2011, 09:07 -
MPC failing to load subtitles on long movies?
By crossmr in forum SubtitleReplies: 3Last Post: 26th Feb 2011, 09:27 -
too long time for encoding .ts files
By Benjy in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 05:06 -
AVI uploading to youtube takes too long, other file formats that cut time?
By jmcconnell86 in forum Video ConversionReplies: 1Last Post: 22nd Jul 2009, 18:50
