I running a AMD 1800 with 600 RAM and over a hundred gigs of harddrive space at 7200rpm. Also have a Plextor 24/10/40A CD Writer and just recently purchased a Pioneer A-04 DVD Writer.
What program would be best for backing up my DVD's. I tried using DVD X Copy and it writes the DVD to my harddrive but when I try to burn the backup I get and error with the program. The error is a microsoft error that closes the program and ask to send a log message to tech. I tried backing up a DVD I own "Twister". I also used Steinberg DVD MovieCopySuite and it says that I cannot copy due to copy protection on the disk. again "Twister"
Any suggestions would be nice.
Thank You,
Craig :P
well since you have dvd x copy once the files are on your hard drive burn them using nero if you get that error message. otherwise just go though the guides on this website.
The error I get is:
DVDXCopy MFC Application has encountered a problem and needs to close.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 03:06 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 15:12 -
Recommendations for dvd-to-zune software? -Corel dvd copy does the trick!
By yoda313 in forum Portable VideoReplies: 7Last Post: 17th Sep 2008, 00:13 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 12:39
