how do i capture DVD menu's to BMP files, so i can import them into maestro? Which software will do this, I already have a hunch that windvd2k does this, am i right?
thanks
If your intentions are to copy DVD-DVD-R then I recommend getting DVDXCOPY by 3-2-1 Studios. This app copy menus and will even split your movie to place on DVD-5 disks. I make SVCD's all the time and tried this program out of curiousity. It make flawless duplicates. Most movies require 2 blank DVD-R's.
The best way, IMHO to extract the menus is to:
(1) decrypt the ENTIRE DVD (i.e., with DVD Decrypter or Smartripper on File Mode)
(2) the menus are usually in VTS_xx_0.VOB (often they are all in VTS_01_0.VOB)
(3) load this file up with DVD2AVI and you can extract either the video sequence or save stills as BMP.
This way you can get frame accurate stills / clips.
Regards.Michael Tam
w: Morsels of Evidence -
Thanks vitualis...Originally Posted by vitualis
Zzzzzzzzz -
Press "B". In my older version of DVD2AVI, you must have it set to RBG24 rather than YUV.Originally Posted by wayned16
Regards.Michael Tam
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Capturing Menus from DVD
By jacklimpin in forum DVD RippingReplies: 4Last Post: 18th Apr 2009, 17:32 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07 -
Menus
By mingul in forum Authoring (DVD)Replies: 4Last Post: 19th May 2007, 07:42
