I never found a way to convert a NTSC mpeg or dat file to PAL (quicktime eont convert all files, with most of them it will say there's some error). is it totally impossible?
mediapipe can do it, ffmpegx can do it, afropic can do it.. just about any good video editing program can do it without any problems.. in fact its simple in all of them.
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
What happens to the extra frames. Do the encoders drop them or do they do a reverse telecine? To explain that better, how does 29.997fps end up as 25fps?
thats a tough question.... with mediapipe you can either choose soft or hard frame rate change, and those both do somethin different, one changes frame durations the other adds/drops frames to get to the new frame rate... i dont remeber which is which since i am at skewl and cant look at it right now... with ffmpegx and afropic im not 100% certain which is the case, i'll look into it more to see if i can find out for you.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Hauppauge PVR-150 (PAL Version) Recording NTSC Source: Impossible?
By darkarn in forum Capturing and VCRReplies: 53Last Post: 16th Aug 2010, 11:06 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Is it Possible to convert PAL DVD R to Ntsc DVD R on Mac?
By monobum in forum MacReplies: 36Last Post: 28th Jul 2009, 20:14 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19
