I used to capture DV tapes into AVI file via IEEE-1394 card
using Microsoft Direct Show codec and
microsoft DV camera device (Default in windows 2000).
I Then I installed Sony DV codec (VFW type) and
suddenly my captures use this codec as default.
I think that Sony is slower and not as good.
However it works with software like CCE SP or Ligos or
virtual dub or anything VFW.
Is there somewhere in registry default capture codecs
used with MS camera device so I can switch between these?
Help Please!!
OK. I found it.
Maybe others will be interested as well, because many NLEs are using
default MS Direct Show codecs that are unusable for CCE-SP or virtual dub.
(Just name Premiere 6)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32\VIDC.dvsd
carries alternative dll (of VWF style codec), that replaces MS DV codecs.
If this is not present it uses Direct Show DV codecs.
Of course This is under Win2000 (Wonder why it is still using NT registry).
Sony Digital Video Codec
By AnchorMan in forum Software PlayingReplies: 19Last Post: 20th Mar 2024, 06:17 -
Need to get a stronger signal - use an antenna pre-amp?
By Mr. Burn in forum DVB / IPTVReplies: 13Last Post: 24th Jan 2009, 17:56 -
SonY vegas 8, codec missing
By connect in forum EditingReplies: 8Last Post: 25th May 2008, 08:58 -
How do I Create a stronger wireless signal to travel 3 floors
By Jabroni4872 in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2008, 00:38 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
