    Nov 2002
    Houston,Tx
    Is there away to change the frame size that is at 352 x 240 14,985fps to one that TMPGenc with load?
    Any help appreciated.
  2. What is the recording of? An explosion? The most I have ever heard in fps is 100. You must mean 14,985 frams. Anyway what is the file type?
    Nov 2002
    Houston,Tx
    I have several movies in .avi format Santa Claus 2, Blue Crush, One Hour Photo
  4. In a new project in TMPGEnc, for the video source place one .avi file. Or you could just click on File, then move down to Project Wizard, then choose the appropriate choice
    Nov 2002
    Houston,Tx
    TMPGEnc won't even load them. I've only noticed this problem with files that are under 25,000 fps. I want to know if there is a way to up them to atleast 25,000fps?
  6. If you have AviSynth installed try this. In your AVS script use this line
    AVISource("C:\yourfile.avi").AssumeFPS(25)
    I am not sure if this will speed up your video.
    If this above does not work to your satisfaction, check out the following link
    http://www.dynapel.com/private/mp_overview.htm
