HI, i speak english bad. but I can read.
hola amigos les saludo desde venezuela, tengo el siguiente problema. utilice el VOBSUB para los subtitulos pero cuando trato de cargarlos con el virtualdub salen atrazados. es decir primero hablan las personas y a unos cuantos segundos aparecen los subtitulos. agradezco su ayuda.
Let me see if I can translate this...Originally Posted by cesarpc
Hi friends, greetings from Venezuala. I have the following problem: I use VOBSUB for the subtitles but when I do virtualdub, the subtitles is out of sync. The subtitles appear several seconds AFTER the spoken dialog. Would appreciate any help.
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
