Results 1 to 15 of 15
  1. Do you know if it's possible to use DVD-$ 9.4GB (double side) with SOny DRU500A/UL?
    Thanks in advance
  2. I had emailed sony about the same question cause I wanted to know and they said it can. It can burn double density and double sided dvds.
  3. I know double side DVD-R but what's are double density DVD?
    Tia
  4. Double density? Doesn't exist.
    Double sided - any good burner worth buying can burn on double sided media. But most software will not say "flip over to burn more". You'll have to author each side like they were separate disks.
    Panasonic DMR-ES45VS, keep those discs a burnin'
    Mar 2002
    cleveland/cincinnati
    double density isnt availableto the general public yet. If sony says that their burner can burn double density dvd-r's, surely they had to have tested this out on a double density disc
  6. what's the Double density anyway?
    =[ vinchi007 ]=
    Sep 2001
    N/A
    I was looking at dvd burners but found that the one I was going for can't actually burn dvd-r!!!
    Can somebody plz tell me (kitty?) What is the name of the disk I want to burn my dvd's to.
    In other words what type of disk is the same as a cd-r?
    How about this one http://www.tigerdirect.com/applications/SearchTools/item-details.asp?sku=P725-2000%20P
    Sorry for being stupit!
    Baker
    My vcd & cvdGuide
    Mar 2002
    buy the sony DRU500A
    you can burn to any disc with this burner!
  9. Baker - the disk you linked to is the Pioneer A04, a solid reliable burner with a good compatibility record. It will only do the minus format disks but the DVD-Rs play in many players (see the DVD Players list to check). At $260 it is certainly less that the Sony which does the minus and plus formats but the sony is about $300 (after a $50 rebate) so you have to shell out more. You might get the A04 cheaper (see webshopping link on the left) since the A05 was just announced which does 4x burning (A04 does 2x).
    The ones to avoid are the first gen (HP100 series and + drives that old) which did not do +r disks (there was a lawsuit after finding out they could not be flashed to work with +RW).
  10. I am a bit confused. Does double sided mean that you have to flip the disc in order to write the other side, or does it support multi layer. Sorry if I asked a stupid question.
    Peter
    Sep 2001
    N/A
    kitty
    Are you saying the + format is better than the - format?
    Baker
    My vcd & cvdGuide
    Sep 2001
    N/A
    Are you saying that compared to the + format the minus is crap?
    BAker
    My vcd & cvdGuide
    Jun 2001
    Surface-of-the-Sun (AZ)
    Anyone who says either the +R or -R format is crap... is full of it. Both are fully functional, but some players won't play one or both formats. *Currently* there is better compatibility for -R simply because it has been around longer. Also, -R media is cheaper AFAIK, so that's what I went with and I haven't had any regrets so far.
    Kitty: The lawsuit issue with their DVD burners is one of the big reasons I wouldn't buy a HP DVD burner. Those were just some bad business practices... but you have to admit the buyers were a little too trusting that "+R capability will be added soon, for free!".
  14. Baker: No, I don't have an opinion on + vs. -. There is much literature on this on the net. I will be getting a Sony DRU500 so I can do both.
    Thorn: I agree - I would not buy a current HP due to lack of customer service and they charge the same for a + drive when you can get a dual drive for the same money. Sony is doing free firmware fixes, something HP should do too.
