how can i take an svcd with 2 chan stero an change to to a 5.1 suround sound is that possable ? and i am going to buy a dvd burner what is a good one and can i take an svcd and turn it into a dvd quality with doublydigital sound ? thanks
the quality will be no better than what the quality of the svcd is (well you can filter it some if nessessary) - every re-encode of a lossy format like mpeg will make the quality worse no mater what you do ... though you can make it pretty close. ..
as for the audio -- you could remix the 2ch mix to 5 channel and add delay to the surround and sum the LFE channel .. but it will not really sound any better and will not reconstruct the origanal 5:1 mix ..
though the aspect of playing it on a dvd disk vs. 2 or 3 cd's is a lot nicer ..
you will have to change the pic size though and re-encode only for that reason really, unless its a xvcd 720 x 480 -
You cant have dolby digital in SVCD, check the specs.
Secondly, you can 5.1 multichannel mpeg, but god luck finding a DVD player & receiver that will output & decode (respecitively) the signal properly. -
k thanks for the responce so fast if 5.1 chanel is no better than i will not bother but i was not sure if i could take an svcd turn it in to an dvd format and some how get the doubly digital back but it makes sence that once you change the doubly digital to 2 chanel stereo
it is lost forever so the svcds i have will have to stay the way they are . dont get wrong they are good and sound good on my receiver the good thing is all my svcds are on 2 cds and i have a lot of them i think i will put them on a dvd . ps how about making the svcd audio pcm would that sound better because my standalone dvd player will support that ? just a thought thanks guys for your responce
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
