  1. So, how could I convert a video from XVID format to .mpg so I could burn it to SVCD? TMPGEnc wont accept XVID files for converting..
    Is that even possible?
    Thanks in advance for replies!
    Apr 2002
    The State of Frustration
    What error are you getting from TMPGEnc? If it is "file not supported", try this tip:
    If you get an error message when opening the video or audio like file unsupported
    or you get an empty(black) video preview window
    or the video look wierd in the video preview window like green or purple or pink
    Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
    -- The Newbie Guides
    Hello.
    Budapest, Hungary
    sorry to interrupt but I1m having almoast the same problem, converting xvid to mpg, xcept.:
    I'm using vdub then cce. when addig the frameserved avi to cce it just hangs up ( closes )
    Thanks for the replies in advance
  4. Thanks Tommyknocker! Got it working now thanks to you...
