I downloaded an AVI file upon burning/encoding with Nero it hangs on 93% encoded. But it plays ok in Windows Media player. How can I make a VCD with this AVI file ?
Results 1 to 10 of 10
Use a separate encoder like TMPG. You'll get better results too.
When you say it "doesnt open the file" are you clicking the buttons at the bottom for "Video sorce" etc
TMPG will convert AVI's thats what it does
If you click on the AVI does it play ok ?. You have the codec installed for that file type ? -
I just downloaded my first avi (divx) movie. At first it would not play with WMP, but I just downloaded the Divx 4.0 codec and it plays now. But, when I tried to open the file with TMPGEnc ver. Beta 12i, it errors with: File "..." can not open, or unsupported. Any ideas?
Yes it does play ok in Windows Media Player 7. but when I open it with the encoder it says "ths file format is unsupported" any ideas
Wow....
Hold on, when the movie was made it may have used any of the popular compressors (Codec's). In order for you to play/edit you need to install the same one as the movie.
DivX 311 alpha, SMR and some new Mpeg4 codecs should all be instaled ready for use.
Take a look on this site, it has some of them listed
http://www.vcdhelp.com/vcdtools.htm
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-08-28 06:37:22 ]</font> -
Try using tmpgenc12a. It worked for me when I had this problem. It's in the tools section on the left. You may also want to try this method in this thread if that doesn't work.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=54213&forum=3 -
I went to the following page again today:
http://www.vcdhelp.com/vcdtools.htm#codecs
and downloaded the Krystal Studio pack. Installed it and now everything is working. I had a feeling there were something to do with all the different codecs out there. Thanks for the advice. I hope this helps as well. I need to get more cdrw's to try the new converted avi out to see if it will work as a vcd (after mpeg-1 encoding with tmpg). I've had problems with previous encoded mpeg-1 when the originals were from my Sony Dig. camera.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
avi to mpeg2 burning problem
By deadwreck09 in forum MacReplies: 4Last Post: 19th Nov 2009, 14:17 -
Problem with encoding AVI files to be played on Lacie LaCinema Premier
By G-Returner in forum Video ConversionReplies: 7Last Post: 18th Jan 2009, 14:29 -
Problem of Burning AVI File to DVD
By AAC in forum Authoring (DVD)Replies: 19Last Post: 14th Apr 2008, 10:19 -
Problem Burning Some AVI Files
By Averc in forum Newbie / General discussionsReplies: 9Last Post: 8th Oct 2007, 11:33
