Hi,
i use DVD decryptor to rip the movie files and then USe ifoedit to create the IFO and BUFS. When i do this the Subtile is chaged to Green color and is in a blured effect. Is there any way in ifo edit to make this look clear or change the Color to white or remove the blur effect.
Thanks in advance
I'm not ragging on you or anything, but if's actually read the instructions on the ifoedit download page, or Doom9.orgs guide, you would know that you need to open the original ifo and copy the subtitle color to the new ifo.It's a very simple process.
Somtimes it just takes Reading the instruction!! :P
Question about Subtitle Workshop
By tcory in forum SubtitleReplies: 1Last Post: 15th Jul 2011, 23:10 -
Subtitle question...
By mjl1297 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2011, 10:35 -
sup subtitle question
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 12:06 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42
