Produced a VCD on a 80minute CR-R using Dazzle DVC.
Is starts fine, but, at after the first minute it starts to skip frames. Another 20 seconds latter the image freezes, the counter go on a little longer, a blue screen comes up telling me that the disk is no longer in the drive (or it needs a cleaning).
In Burning other VCD's this is the first one to give me any trouble. The only hint of what may be wrong comes when I use AVI2MPG to play the VCD. At the freeze point I get the following message:
Waiting for Video Frame Update
Checking Direct Draw Sample Update Completion Status
Unable to Update IDirectDraw Sample
Then the frame counter goes wild.
VCD Information:
Video:
width: 320, height: 240
first frame: 0, number of frames: 64166
Audio:
sample rate: 44.1 kHz
channels: stereo
bits per sample: 16
number of samples: 94419072
What went wrong?
<font size=-1>[ This Message was edited by: Ensign on 2001-08-24 06:31:53 ]</font>
