i am currently downloading the all of the red dwarf series and they are coming as mpeg files at 300mb each. with these file sizes i can only fit 2 per disc. is there anyway that i could convert these files to avi and reduce the file sizes.![]()
8)
:P
Load them into a program like VirtualDub and save them in DivX format.
Check the "Tools" button on the left panel here.--
Will -
ive tried doing that using divx pro 5.0.2 codec and my avi file ends up 100mb larger than my mpeg file
Next step would be to try Kwag's templates. They are for MPEG, but he claims he can get up to 180 minutes on one CD with "acceptable quality".
These are non-standard templates and as such will not work on most stand alone boxes.
Actually, with each re-encode you will lose quality, so I would suggest you leave the MPEGs as they are. Blank CDs are very cheap these days. We can get 100 Generic CDs for $40.00 Canadian. That is like $30.00 US.
At $0.30 per CD, why worry?--
Will
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49
8)
:P
