I gonna encode E.T to a SVCD, 115 minutes long, should i choose 2 or 3 CDs?
Anyone who already have encoded that movie and can tell about the quality, and how many CDs they used?
Thanx!
AMD XP 2600+ Barton * ASUS A7N8X-X * 256 DDR pc3200 * Radeon 9000Pro 128mb * 280GB HD * WinXP Pro
I used two. I think I cut the credits out to get the time down a little. It looks great. However, you must consider that I only have a 27inch tv. My rule of thumb, is to use three if it is over 121 minutes. I use 192 for the audio, and this will keep the video over 1600.
I don't know if this helps, but that's what I do and I am very picky about video quality. -
Originally Posted by bbeiler
my suggestion would go forr 3 cds, the quality will be amazing...no need to lower audio bitrate (standard 224 kbit audio would do) and no need to cut out credits -
I just put ET in again to check the quality. I know this sounds crazy, but I would guess that at a viewing distance of about 10ft. on my 27 in looks nearly as good as the original through 90% of the movie. Ofcourse through seens of complication pixelation is efident. And, ofcourse, on a larger TV or closer viewing distance the difference may be more significant.
I also agree with poopyhead, if you go with 3 cd's then I would keep the audio at 224 and the credits. However, if you go with 2 (which I think the results are pretty good, atleast for that movie, 'sometimes it matters on the complexity of the movie') then I would cut the credits and set the audio to 192. You can't hear the difference, and even though it's only 32 kb/s every bit 'no pun intended'counts.
One more thing. If you have a changer, don't even think about it and go with 3.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
