Actually what i want to do is get the audio from a .rm file, but tmpgenc says file not recognised. Anyone know of a plugin i could use, or a seperate programme. the video is shocking but i want the audio as it is a live Linkin concert and i want it on a cd.
Anyone??
Thanks.
ok for rm convertion programs there are very few however of the ones that there are I know that one of the best ones that I have found is called
TINRAgui this program works like a dream it converts the video and audio into a .avi file and then you can use tmpeg or adobe to edit convert or whatever you want to do with it. The only drawback is that you need quite a bit of hard drive space as the avi files are normally uncompressed and therefore are normally quite huge depending on the length of the video.
Also I belive there maybe a codec needed to use TINRAgui but I'm not sure as it is a long time since I installed it. Hope this helped.
P.S if you want it go to:
http://guiguy.wminds.com/downloads/tinragui/
TMPGEnc Authoring Works 4, no audio with AVI files
By aln688 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2010, 17:02 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 22:09 -
codec for realmedia
By pcb in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jun 2008, 08:47 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 16:34 -
Best RealMedia player?
By Brent G. in forum Software PlayingReplies: 1Last Post: 19th Aug 2007, 23:28
