I'm having problems with tempgenc - i've used it before and considered myself fairly proficient with it. However, i have reloaded it and now on the wizard page, i cannot get anything other than "CBR standard format" to show.
I've followed the help pages to the letter and the only difference is the message on the wizard first page - on the screen dumps shown the CBR message changes to PAL or NTSC depending on who's version you're looking at.
VCD's i create now will not play on my dvd player whereas previously they did..... Help!!!!
Load the standard VCD template. Load the unlock template (in the *Extra* directory). Save this template with a new name. Now it will be available to you through the Wizard.
sorry to be thick but how?
i've located the files you have said about but when i try to open them i've got no programmes to open them with .... i've tried attaching them to tmpgenc.exe to open them but the system doesn't like it -
run TMPG first and IN the program hit load. Then select the template you want, hit load again and select the unlock-template.
If you're having problems with the wizard and were ok before without it, just turn the wizard off. I don't know if the load/save buttons (or any advanced features) are accessible with the wizard on.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
