Hello everybody, i need help for the movie Signs that i've downloaded.
It doesn't want to work on wmp or zoom player, i have been able to watch movies without great problems, i watched last night High Crimes.
the file "Signs.TC.SVCD-TWCiSO.CD1.mpg" crashes tmpgenc, gspot2.0 e wmp i don't know what the hell to do.
Plus i have another moviewhich has an offset between the audio and the video and it gets wider as the movie goes to the end. What can i do?
as last i get a little problem using wmp when i open a movie its all blurry. the problem goes away if i restart the machine. otherwise i use zoomplayer but sometimes it does it too and i have to restart anyways. thank you for you valuable time spent on me, bye for now
Update as i am almost posting the message. gspot didnt crash but took forever...but all the fields are n/a...is it a movie or what????
Full agreement here Fozzee.Originally Posted by Fozzee
The filename indicates that the file might be in SVCD format, any of the software DVD players should be able to handle it.
If not, you might want to check where you DLed it from, maybe they have a note saying "To play this file you need _______ codec installed.--
Will -
Thank you guys, I downloaded a dvd player to watch Signs because it
was a svcd. Is there a good program that has everything? I mean that
playes divx, vcd, svcd, mpeg, avi and evrything that comes to your mind?
I am really tired of bouncing from one program to the other...
I read how to udjust the offset thing in a movie and it seems a bit
complicated...anyhow, thank you for your attention, and let me know the
programs that you think are best as a all in one solution...best regardsLast edited by pfmboidi; 18th Nov 2013 at 10:45.
Viewing problems: movie from dvd to hdd to TV UK...
By iancur in forum Video ConversionReplies: 7Last Post: 3rd Feb 2011, 15:58 -
BD Rebuilder Movie Only Problems!
By kings322 in forum Blu-ray RippingReplies: 18Last Post: 1st Jun 2010, 06:11 -
problems burning movie file
By lynette00 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 06:40 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 14:12 -
Problems with subtitles in movie
By Lythrana in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 16:27
