I have a few videoclips on my computer, and they are in XVid format, just a few minutes ago I downloaded XVid codec, and before that when I tried to watch those videos, video didnt show but audio did.
Now when I have the codec, and I watch them, the colors are all screwed up, like yellow is grey etc.. I use Winamp 3.0 as a player.
Does anybody have any info what's problem & how can I fix it?
i have had the same problem but have found that if you convert to mpg using tmpge(if you have the correct codecs) the colours are fine
How to encode video from raw RGB (grayscale) to Xvid (color)
By Fixer in forum Video ConversionReplies: 10Last Post: 19th Aug 2011, 10:55 -
Chroma/Color Bleed Issues In MPEG2-->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 8Last Post: 25th Jun 2011, 22:11 -
Color streaks appears once converted to Xvid
By 24fps in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 04:45 -
Huffyuv to Xvid color correction - advice please
By spicediver10191 in forum Video ConversionReplies: 12Last Post: 11th Apr 2009, 10:03 -
Xvid 8 bit color depth resoultion problem
By afcoff in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 00:50
