When i converting divx to vcd i will get some audio sync problems in the middle of the movie and then suddenly its gone again. im using audiodub to extract audio to wav and the tmpegenc to make the mpg file.
I have tried it on a athlon and P4 its the same.
Does anybody have a solution for this)
what i do to not get any error converting or audio synchronize problem is.
1.Encode the DiVX video to MPEG-1 using TMPGEnc( no audio )
2.Open the DiVX with Virtualdub then extract the audio as wav.
3.Convert the wav to 224kpbs 44Hz MP3 Blade using dBpowerAMP Music Converter.
4.Multiplex the video and audio using TMPGEnc.
I never had a problem with audio sync.
You might want to try this method.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
