I have made a vcd but am unable to play it on my PS2 or Xbox as they are not compatible, however I was wondering if it is possible to convert the films into the DVD format, and then put them onto a CDR and play that in the console's DVD player. Effectivley fooling the console into thinking it is using a proper DVD film. Is this possible and if so how would I go about it.
Yes this is possible it is called miniDVD, however this format is compatible with very few players, and will not work on your PS2 or XBOX
I got the PS2 last xmas so i guess i have the latest version. in the manual it said it could play 8cm dvds. was that referring to minidvds? how would i go about converting it to dvd format to trick the ps2 into thinking its a dvd when its a cdr? what program do i need? thanks!
An 8cm DVD is not the same as a miniDVD. A mini DVD is video that has been authored for DVD but has been burned on a regular CDR (these are not playable in the majority of DVD players). The 8cm DVD's are just smaller diameter DVD's and thus hold less data. These will play in all players that can play regular DVD's
How to put clips together in AVCHD/m2ts format?
By vpelton in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2011, 08:31 -
Restoring video clips after format
By better life in forum ComputerReplies: 9Last Post: 25th Nov 2009, 00:58 -
Copy movies/youtube clips to a DVD format
By RubyBlu in forum Newbie / General discussionsReplies: 4Last Post: 1st Jun 2009, 19:32 -
Video Clips For Buttons - Format & Spec?
By EViS in forum Authoring (DVD)Replies: 5Last Post: 19th May 2008, 08:21 -
Any S/W Players that will play PAL format clips ?
By Seeker47 in forum Software PlayingReplies: 2Last Post: 17th Sep 2007, 14:10
