  1. If a movie is 24 fps which format should I use. Like NTSC, NTSC Film, or Pal
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    well where do you live would help answer that question more fully ..
    but ntsc film if you live in n. america or japan
  3. Well I live in North America. I had to use just the NTSC. That worked. It wouldn't with the NTSC film which was my first try.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    well thats film -- 24fps .. you picked the wrong one .. 23.97 internal / 29.97 external (or 23.97 and use pulldown) .. same diff ..
