  1. when i try to add an mpeg-1 video it says:
    "MyDVD cannot use this file. It has missing sequence headers before each GOP. Please consult the manual of your MPEG encoder for further information on creating DVD-legal MPEG files."
    i encoded the files im trying to use with tmpgenc and used "VideoCD (NTSC).mcf" should i re-encode all the files and use the "DVD (NTSC).mcf", i am re-encoding one of the files now with the dvd template but it is going very slow and i dont want to have to re-encode all the episodes of the show i am making a dvd of, so is their any other way to make a dvd with the mpeg-1 files?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can use this tool and not have to re-encode - This tool inserts sequence headers in every GOP without reencoding : http://www.vcdhelp.com/download/MPEGSequenceMakerv02.zip
    there are other tools which will also do the same thing ..
  3. thanks, i didnt want to have to re encode everything. i hope this works well.
