My goal is to produce MPEG2 CBR stream at the max btr (respect the svcd standard). I've used tmpgenc in CBR mode with video(2590Kbs)+audio(128Kbs). The mpeg produced plays fine in my samsung 611, but at the start of the track there are some freeze (due to the high Bitrate). So I've tried to inspect the mpeg file with bitrate viewer tool. In fact, while the program load the mpeg , it shows an average bitrate that is bigger in the first part of the file.
I've done an other small test. I've cut the same file (with tmpgenc) in more parts and then I've checked them with bitrate viewer. Obviously I expected the bitrate was bigger for the first chunk of the video. Instead all the chunks have a similar average bitrate and moreover, all have the same behaviour of the full video : average bitrate bigger in the first part of the chunk.
Where is the mistake ?
Then I've tried the same Tmpgenc setting with other mpeg files but all of them play a little bit freezed at the start. The easy solution is to decrease the bitrate, but I would like to understand why Tmpgenc produce a variable bitrate (and always at the first 5 seconds of the stream !!!!)
Thanks for any answer.
Maybe you should e-mail the author of TMPG. I encode at 2500k, CBR, with no problems. But... I'm using a Pioneer DV-343.
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 03:40 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
