Good Evening all, as the header says, when I try and extract audio from a DivX file it tells me it can't find compressor for format DX50 but when I look at the file with Gspot is show everything installed properly, any ideas as to why?
You need to install the divx5 codec
It is installed, the file plays fine, that's the strange part and when I run Gspot it too reports the codec as being installed and working properly, maybe a setting in VDub I have to adjust?
Have you installed the latest version.
http://www.divx.com/divx/
I seem to remember having a similar problem. I had divx5 installed, but not the latest version. Updating solved the problem, -
We have a bingo, thanks so much craig! I already showed having 5.0.2 but what the hey, it works now, thanks again.
No problem
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Latest "Best TVs" Consumer Reports arrived today. Winner Samsung
By edDV in forum Latest Video NewsReplies: 1Last Post: 30th Jan 2009, 23:46 -
Problem.. DGIndex reports "motion code error" :cry:
By _migz_ in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 06:09 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
