I have some divx and avi format movies that i want to burn in vcd format so i can watch it with my dvd player. And i have no idea where to start. What would i need to do to burn a vcd. Please help me out.
The best place to start is to read the how to guides. That's what they are there for.
you will need avi 2 mpg use decompress .exe to uncompress audio then run the uncompressed file through tmpeg to convert to mpg then write as a vcd using your favorite burning software but converting a 1 1/2 gig file takes about 8 hours
Hi,
I use a burning program called nero. It also converts .avi to vcd format and burns them automatically.
Most .avi's are too big to fit on one cd. Nero also overburns, however, I have not figured out to use it. I use a splitting program called virtualDub instead.
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 15:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 07:40 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 16:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 19:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 22:30
