i have a vcd file that is 1.3GB. i want to put it on an 80min CD-R. what freeware programs do i use to cut the file into seperate parts then burn? please be detailed, i tried to use vcd cutter but i didnt get how. any freeware program please. thanks in advance
Results 1 to 16 of 16
TMPGenc can do this. You can download it off the Tools Section.
You open TMPGenc. Goto.. File->MPEG Tools
then clikc on the merge/cut tab
then load your MPG in, then hit the edit button -
Use tmpgenc, merge and cut tool to cut the mpg file. You add the file, select mpg video cd from the dropdown box. Select the file in the window, click edit. Select your start and end points with the slider bar, select an output file name, click run
If you are working with VCD compliant mpg files, 1 min = 10mb approx.
Depends on the bitrate you use. SVCD bitrate is not set like VCD bitrate is.
rougly twice as much 20MB per minOriginally Posted by TheeNotoriousOnee
Not necessarily, like I say you can vary the bitrate for SVCD, so the filesize could vary considerably.
what if i encode it to svcd and tell it to fit it on 99% of an 80min cd-r? would that work? cuz the thingy says the file is 236% of the cd-r, but i put it on 99%, would that effect the cd?
what the hell is bump and why do people say it?Originally Posted by TheeNotoriousOnee
does it mean "bump" as in "bump" to the top of the latest posts? -
bump means to get the topic back on top of the list so people would notice it, now please answer my previous post
Do not bump your post, particulary not after only 25 mins. This resource is free people are not obliged to answer your questions, so please be patient.
If TMPGEnc is saying it needs 236% disc space and you encode it so that it fits on 99% disc space, stands to reason you are going to be loosing something somewhere. Personally, I think the quality would suck trying to cram that much on 1 disc.
Use a bitrate calculator, to see what bitrate you need to fit your film on both 1 or 2 discs, then encode a small portion of the film (high action scene would be good) at these 2 bitrates. And see if you can tell the difference. If you are happy with the lower bitrate, then use it and put your film on 1 disc.
[FR] Cutting TS Help Me Please
By KERNEL32 in forum EditingReplies: 5Last Post: 26th Feb 2010, 14:38 -
cutting mkv
By tonyburns in forum EditingReplies: 2Last Post: 26th Apr 2008, 13:04 -
Movica not cutting where I want it to
By ThePMonkey in forum EditingReplies: 10Last Post: 29th Aug 2007, 23:42 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 19:55 -
cutting and splitting
By ichigo15 in forum EditingReplies: 1Last Post: 18th Jun 2007, 21:01
