Hi all, I have an avi movie that I wanted to convert to VCD so
I could play it in my dvd player.
Right-clicking on the .avi file gave properties as follows:
audio format: MPEG_layer 3
sample rate : 48 kHz
frame rate: 23.976 frames/second
ok, so this is what i did:
I used virtualdub to extract the audio as a wave, I went "File" -> "save wav" and saved the wave (under "audio", it was set to "direct stream copy")
Then using TMPeng, I used the .avi as the video source, and the extracted
WAV as the audio source.
I encoded an hour of the movie for the first VCD disc,
then encoded the last 40 mins for the second vcd.
So, the first disc was perfect, great sound an good picture, but the second
disc was terrible, the sound was out of sync by about 10 secs! Not just 1 or 2, but 10!
Why did this happen, especially if the first disc was perfect?
I used the same setting and files? why is the sound out of sync?
Hope somone can help me. Thanks...........Steven
Originally Posted by sterankin
You need full processing mode, and make sure you have no compression set for the audio. This will decompress the audio to a pcm wav file. At this stage you can also convert from 48KHz to 44.1KHz. You then use this wav file as the audio source when you encode to mpg. -
where do i set it in virtual dub so that there is no compression set for the audio?
Thanks for you reply. -
Audio, compression. Pretty self explanitory
looking for some clarification on current projectors
By Seeker47 in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2009, 10:48 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Advice required - Formats, splitting, software, outputs
By glinscott in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2008, 07:00 -
Connecting Freeview to Panasonic DMR-HS2 Advice Required!
By wilberfork in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Aug 2008, 07:23 -
Convert AVI to DVD best method advice required please
By vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 10:01
