  1. I have had major problems using Nero 5.5.9.17 when trying to create a DVD compatible disc as DVD discs created dont work in DVD Topset Players especially on a CyberHome DVD Player! - comes up Bad on the DVD Player - Try using Stomp RecordNow MAX, Version 4.50 Which Works! You can download a demo which runs for 30 days, but have found it to be better than Nero for creating compatible DVD-R or DVD-RW discs
    Regards
    Nathan
    Feb 2002
    Oregon
    Nero has compatibility problems with a number of desktop players. Using identically authored files (and identical media) Prassi burned DVD-R's play on a lot of desktops that won't play Nero burns. However, some desktops have no problems playing Nero burned DVD-R's.
