  1. I cant install it, it freezes after the updating registry part of installation. What the f*** is wrong. when will divx 6 come out
    PA, USA
    just a guess here... but maybe its your computer?
    DivX installed/installs fine on my 2 computers, and im sure many others here can say the same..
    You might want to try installing the Nimo Codec pack which include the Latest DivX codecs i believe
  3. have you been to divx.com and searched in forums for installation issues?i had a few probs when i first installed 5pro and it ended up being conflict with another codec i had installed. hope you figure it out because divx can be very nice.
  4. I'm getting very desperate now, can somebody send me your DLL and AX files?
    Jul 2002
    God I love digital video!!!
    "The software said Win XP or better, so I Installed Linux"
    PA, USA
    Even if someone would send you these files (which i doubt anyone will) its probably not going to do you any good considering you said that it freezes right after the "updating registry part of installation". More the likely the files arent registering properly, and in which case, it doesnt much matter if you have them or not.
    Best bet is to either try another install of it (Nimo Codec Pack) like i said, or go with hoola_loop's suggestion of reading up on the Divx.com forums for a fix.
    Jul 2002
    Erie, PA United States
    It's been a while since I made a post here so here's my suggestion:
    Format C: /V
    Warning! I'm baaaaaaaaack
    PA, USA
    Format C: /V
    heh
    i perfer Format C: /autotest
