  1. hey whats up? currently i have a dvd (a boot for that matter) of a film. what they did when they made this is instead of having the film as one file (like a normal dvd) they split the damn thing into 3 titles, so when title one is done, it goes back to the menu and to keep watching the film you have to select title 2, etc.
    i want to rip this back to my pc and reburn/author it properly (which is easy). However i want to convert its lpcm audio to ac3 (so i can add more stuff to the disc).
    My problem is here, i can copy all the vobs fine,etc and if i use smart ripper ithat will al least demux one title (not the other two). So lets skip ahead. i have all the vob files used for this disc on my pc, however tmpg or anything else i have tried to demux with DOES NOT see the lpcm audio stream. the only program that did see it was smart ripper but since it only sees one vob title as the film and not the other two i cannot demux all the audio streams for them.
    Does anyone know of anykind of demuxer or other program where i can demux the lpcm audio back to a wav? thanks again--
    Dec 2001
    South of Sydney. Aus
    Try vobedit 0.6, I use it to demux all audio tracks when authoring.
  3. thanks for the info. i wasu sing an older version of vobedit and this older onei had only gave info foran ac3 stream demux. i downloaded the newest one and this solved my problem
