i was wondering if any one has any ideas on taking a .avi file and encoding it to make it better. Like quality and sound and such i have tryed with virtural dub but i dont know settings very well so if someone could help me it would be great.
dbzman6709,
Nothing will. Anything anyone tells you here, is pure waist of time. And,
especially to a beginner. Especially!!
Buy the origonal movie and encode it yourself, as you'll be happier then.
-vhelp -
Well It depends, If the picture just has some Macro blocks then apply a noise filter. If its anime then you can definately make it look sharper and better. But as Vhelp said. Nothing you can do would make the video better. Unless you had a $10,000 studio rig built for video.
Adding bitrate to video wont solve the problem either. Its just wasted bitrate. -
its a movie i downloaded of kazaa friday after next and i was wondering if i could make it better any thing would help
Making Someone Look Bad :)
By HoosierGuy in forum EditingReplies: 9Last Post: 16th Dec 2011, 13:37 -
Popcorn MKV AudioConverter is making bad audio, alternatives?
By _ck_ in forum Video ConversionReplies: 3Last Post: 28th May 2011, 13:57 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
