I've recorded my wedding in Brasil, with the local PAL system.
Now I live in Europe with a different PAL system (it seems to me that one of the two is PAL-G and the other PAL-M, can't say which one)
Does anyone know how can I capture my videotape? It's captured always in black an white (while it's in colors) and apparently with a wrong frame size: the aspect ratio is incorrect and a portion of each frame is copied to the bottom.
Thanks again![]()
Brazil uses PAL-M which to me is similar to NTSC except for the color subcarrier.
The main difference between PAL and NTSC is that PAL runs at 50hz and NTSC at 60hz.
If you play a NTSC tape in a "recent" PAL VCR it will output someting called PAL-60 (instead of PAL-50).
PAL-60 captures usualy end up in blach & white.
I've read somewhere (can't remember where) that some people where successful capturing PAL-60 using DScaler. http://deinterlace.sourceforge.net/downloads.htm
I've never tried myself, so I can't say more.
uteotw -
check this link
http://www.vcdhelp.com/forum/viewtopic.php?t=118947&highlight=pal60+capture&sid=5c2d38...e97b2e7338af99
and check these for technical info
http://www.tenlab.com/worldtv.htm
http://www.ee.surrey.ac.uk/Contrib/WorldTV/compare.html
uteotw -
Hi
I use powervcr2 u get the option to set your "video signal format".
This has a number of fomats in it based on various pal and ntsc signals.
I assume that if u played your video thru this software you could try the different formats and eventually one will work.
Fozzee -
Buy a AIWA multisystem VCR. There might be others but AIWA is the lider.Originally Posted by nanifra
Such a VCR can play/convert from/to any existing TV standart, including Brasilian PAL. I am sure because I remember when I saw for the first time the words "Brasilian PAL" on such a player. The price must be about 300USD.Best wishes,
UP -
From the first post i assumed the video played ok from your VCR to your TV ??
Does It??
Fozzee -
Thanks to all!
I will try your suggestions ... and hope some of them work!
Fozzee: unfortunately the wedding tape plays to TV without colour. Just some tiny (and annoying) colour bars appearing sometimes as flashes around the screen, without any accordance with the picture. The frame format appears to be ok on TV (circles are round and faces look good) but the capture card doesn't understand and displays frames compressing the image and copying the upper portion of the frames to the bottom with a different aspect ratio (tipically the foreheads displayed also at the bottom of the screen): a mess!
The original capture software shipped with the card, succeeded in showing the right colours and the right aspect ratio, but hanged after few seconds.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
I need PAL format help...
By jenn00_v in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2009, 17:29 -
DMR-ES15 and PAL-N format video.
By goal in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Apr 2008, 00:59 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 00:26 -
Actual format PAL??
By KingBongo in forum ffmpegX general discussionReplies: 5Last Post: 11th Jun 2007, 07:29
