I've been trying to capture my home movies to make a svcd using a matrox mystique/rainbow runner, virtual dub w/picvideo codec set to custom 480x480 in a athlon 1.4 computer but am dropping more frames than I capture. Anyone gotn any ideas as to the best way I should capture with this card to make svcd?
Thanks, Pat
O.K.
Can I capture at a different resolution and convert to 480x480, and if so what is best resolutin to capture at? -
O.K.
Can I capture at a different resolution and convert to 480x480, and if so what is best resolution to capture at? -
What's wrong with rainbow runners own capturing? and then use TMPGEnc to convert to SVCD?
You can use anything above 480x480, higher resolution often means better quality. TMPGEnc will then resize the image to 480x480 when encoding.
I don't get why Blade Runner is special - ok movie but a classic?
By yoda313 in forum Off topicReplies: 24Last Post: 28th Feb 2011, 17:36 -
Putting the Mystique/Rainbow Runner out to pasture...
By logic7 in forum Capturing and VCRReplies: 2Last Post: 7th Dec 2009, 16:45 -
Rainbow effect
By rism47 in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 16:47 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
Blade Runner Briefcase Dangerous Days (Disc 2) menu problems after shrink
By jrshull in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 13:49
