Hi,
I have a Pinnacle PCTV capture device. I want to make svcd's from tv-programs and vhs-tapes but that is not possible. All the options are greyed out, I can only make recordings in AVI MPEG1 format. It should be possible to record directly to SVCD and VCD format. It worked fine before my latest HD-crash... Does anyone know a solution for this?
ciao
belum
You did not mention what application are you using for capture. If Pinnacle software ie. Studio 7, try using another apps instead. I had encounter a lot of problems w/ this software. You can try Virtual VCR from this site or if $$ doesnt matter Cyberlink's PowerDirector or Ulead's Video Studio 6
With the normal drivers and applications these options are allways grayed out (at least as far as I'm aware of). These normal drivers are available on the Pinnacle website. If you want to capture directly to vcd or svcd you will need the pro version that, offcourse, you can buy on the Pinnacle website. If, as you say, these options where available at first then you must have had the pro version installed previously. So check if you've installed the exact same drivers this time.
On the other hand you could try capturing with iuvcr and then converting to (s)vcd with TMPG. I do it all the time and it look MUCH better that way than with studio PCTV... but it also takes a lot longer.
Jack -
Ahh this was the trick, thank you very much. I installed drivers from the website because I left my Pinnacle PC TV Pro cd elsewhere. So now I re-installed from the cd and everything works fine now.
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 05:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Capture DV with datestamp please - exploring options Pinnacle Exsate Ensoft
By Nicola-Pickle in forum Newbie / General discussionsReplies: 11Last Post: 3rd Apr 2009, 07:03 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 03:20
