if a dvd player doesnt play vcd or svcd is it becase of the format or because the player cannot recognise cdr/cdrw?
Guest
If VCD it is almost certain a CD-R/W problem cause most support original VCD.
www.vcdhelp.com/dvdplayers -
I suggest you check the DVD Players list on the left. Make sure you read the reports an comments for your player as many times these can give additional insight. Some of the newest DVD players do not support any VCD format.
Basically, could be either or both.Originally Posted by boboyo
8 million reasons not to use Sprint
By deadrats in forum Off topicReplies: 0Last Post: 2nd Dec 2009, 18:46 -
XviD Settings for PS3 & XBOX360 Compatibility?
By blackflames in forum Video ConversionReplies: 7Last Post: 21st Oct 2009, 07:15 -
Need reasons not to buy a Kuro 600A
By KBeee in forum Off topicReplies: 11Last Post: 15th Jul 2009, 13:47 -
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 20:29 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 18:07
