hi, everybody! i'm new here. i figured that if i needed help with anything VCD or DVD related, this would be the best place![]()
anyways, i have a very old laserdisc and i want to make a DVD out of it. i was wondering that is this possible or not? if so, can someone PLEASE show me how to make a DVD from my old LD? any info would be appreciated.
Dont have much time to look into it deeper but try this link
http://www.wwug.com/forums/digital-video-editing/020716213925.htm
its just a news forum somewhere, but gotta start somewhere
good luck, 8)
TLTwThe Hellsing family will purify this world... -
Ok your lookin at a guy that one time owned over 500 Laser discs Now I am down to 125, but to make a backup of your Laser disc to DVD you must have the following for the simple fact, Laser Disc is Analog, not digital like DVD, so there will never be a way to rip or get off the encoding on these discs, so here is what you must do, 1st of all NO I repeat NO laser Disc has any copy Guard, could never make it work so that is taken care of here are your choices.
1. Buy a DVD Set Top recorder and record your laser discs to a DVD-R,
(this is the solution I like best)
2. Capture your laser discs with a good MPEG2 cpature card that can do bitrates from 2500 to 8000, mine does all the way to 12000.
Burn your finished capture to a CD-Rom as SVCD or author it to a DVD-R or DVD+R with the DVD Burner in your computer.
Now mind you you can do this but only for backups, you need to still keep your original laser discs.
I have a Panasonic E10 and E20 Set top DVd recorders and Laser Discs come out beautiful on a DVD-R.
I would replace any laser disc with a new DVD if possible, I have done that to a lot of mine, but I have a lot that are still not out on DVD
Aladdin, Lion King, Star Wars Triology, etc..... -
thxkid,
I too have more than a few old laserdiscs!
Your post above had me thinking. As I am trying to figure out this capture and burn process for old Videotape, I wonder if the following would work.
I do not have a capture card. However I do have a Canon ZR50 Mini-dv
camcorder that allows analog pass-thru. I have NO IDEA what the bitrate, encoding, etc. is, or even if it is set by the camera or the software using to capture. It comes with Shobiz.
Anyway, would putting the laser through the Canon, and then via Firewire into my Windows XP PC get me what I needed in order to burn a DVD???!!
BJBBJB -
yes -- but you would still have to encode it from DV to mpeg2 and author it .. but capture in DV is pretty popular - though it is a compressed lossy format.
you can get very good quality ..
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26
