I've sucessfully created a XVCD of a downloaded movie. It was perfect, I added subtitles and all... kick-ass!
There's just one more thing I'd like to do to make it 100%... the final volume (actually, the volume in the original .AVI was already like that) is very low, I think it was ripped as 5.1, I don't know.
Well... can I increase it with some filter? Or do I have to extract the .wav, edit it (increase the volume) and re-encode it together?
If you are using TMPGenc you can increase the volume
Click setting button
select audio tab
click audio check box & select setting
Use change volume to crank it up.Panasonic DMR-ES45VS, keep those discs a burnin'
AC3 Filter volume problem across speakers.
By chrisssj2 in forum AudioReplies: 1Last Post: 24th Feb 2011, 09:36 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 19:19 -
volume increase
By natty in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 10:08
